How many times have you started your 650 up and realized you forgot something. Your only choice was to shut it off to be able to go get what you forgot. In a cold start scenario this can be bad for the bike. What can I say, I can be forgetful at times.
I know doing this has been mentioned before, and I feel what I've done is a fairly safe workaround for the issue, so I'm posting the results. Having to simply tap only 4 wires in the harness, 3 being in the same area, the installation was fairly simple. :thumbup:
Up Side:
Now with the side stand down everything works the same as before. The bike won't start or run. But after this mod, if I engage the parking brake, the bike thinks the side stand is up and the center stand is down, regardless of what position they are actually in. 8)
Even if by some quirk of fate the bike starts moving, at least it won't come out of first gear. Of course, if I release the parking brake with the side stand down the bike will shut off.
Down Side:
By using the existing parking brake switch, it is possible to make the switch trip with little or no brake applied. I personally can live with that, but a second switch could be used to only trip after full brake is applied. Unfortunately this adds a lot to the complexity of the mod so I opted to trust myself to make sure it's fully engaged.
Up Side:
Down Side:
