Well, I set about this job today.
First hurdle, one of the bolts securing the leg shield (m6) just would not come out, it would turn but not advance out - drill job!! :twisted:
Second hurdle, getting the engine to TDC! :twisted: I was on my own, family at work/school. Turn the engine on the left side of the back but the indicator is on the right - boy was I fed up of doing turns around the bike - I very nearly set up my video camera & monitor so I could see what was going on. :wink: (Next time I will!).
Valve clearances - easy peesy lemon squezzy! Well apart from the access. The service manual for the Olde Burgman details removing the carburettor to gain clear access - me no fancy that! I just disconnected and swung to one side and tied it out of the way. Inlets were slightly tighter than spec say 1 or 2 thou, Exhausts were a wee bit more tighter than spec, say 2 or 3 thou. Adjusting in the restricted access was just a bit fiddly.
Reinstall cylinder head cover :twisted: :twisted: :twisted: Tried out my new torque wrench and sheared one of the securing screws!! :twisted: :twisted: :twisted: Yes it sheared below the surface so out with the drill - Oh No! - I cannot get a bead on it because of the seat bracket. Luckily the flexible drive shaft, dremel and the trusty 'eazi-out' managed to retrieve the varmint. I was sweating though and thought I was getting into head removal!
I phoned the dealer and new bolt available Thursday.
Oh well, not a good day.
I did take some pics and will post later.
TTFN
TTFN
