1 - 4 of 4 Posts
I dutifully tried to perform this as part of my 9,000 mi. maintenance, but the cap screws attaching the exhaust pipe to the engine seem impossible to get a straight shot at except for one. Anyone have any hints for doing this tightening without stripping out the cap screws?
Paul, you could try a set of ball end Hex wrench's. You can not crank 100's of pounds on them but for a small bolt they work fine. They come in SAE and Metric. Example below of SAE.
http://www.northerntool.com/shop/tools/ ... pla&ci_kw={keyword}&gclid=CNDylZ3PobMCFYN_QgodwiIA_A
removing the exhaust bolts is pretty easy, nothing to it... just need the right tools...
all you need is a good 6mm hex socket with an extension bar.
you will have to lay down on the floor to reach those bolts if the bike is not elevated.
good luck
[youtube:6u5sebyk]IWYgWvZrBMw[/youtube:6u5sebyk]
I would recommend this set from HF, it has a 12 mm that you can use if you ever remove the front wheel and a 17mm if you decide to service your forks
-- HF Metric Socket Set
I used ball end metric sockets. and did not remove the tupperware when changing my pipes out.
1 - 4 of 4 Posts
