You can use piggyback connectors on the wires that run to the power socket on the rear side.
The Front panel is quite easy to remove for access.
billmusser said:I have difficulty finding any kind of a short plug except the 5volt one from radio shack. maybe i can find a japanese one somewhere ..I hear they are shorter .
not sure by tying on to the wires in the back of the accessory switch how i can avoid using the original gps plug since it drops the volts from 12 to 5v. If i could connect to the back of the accessory lighter this would eliminate the wire from the battery true but would still have to put the 12 v plug somewhere and figure out a way to get the line up to the gps ...on the handle bars brake mount
