1 - 15 of 15 Posts
I have a 2012 400 and horn isn't working. when i hit the button nada. lights don't dim no cue that it is even drawing electricity. I know its under warranty but unless it's something major or needs new part or something, I'd rather just do it myself. Hoping it's just a loose connection and I'm hoping for any advice or insight.
Thank you
marcus
have you done any mods? bike stay covered or uncovered? looked in wheel well to see if wires broken?
Check the Fuse Box , It may just be a Fuse out, Fuse is located left side under Dash.
it's not Rare for the Horn to Quit when it comes to the Horn itself,
Elliott,
Agree with Mikey it is likely there is a modded horn in the circuit and the wiring is damaged/compromised.
thank you for the replys. I checked the fuses and saw nothing unusual but the horn stated working and I've had no problem since. HMMM? I guesss all well that ends well.
Glad you now have the horn working - BUT too bad that you never found out what the problem was..(???)
Could have been a bad connection, which got corrected during the investigative work.............who knows?
Just pulled my 06 out of the garage after a long winter. Battery was dead. Of course I neglected to put it on the battery tender which I own. After a little charging the Burgman came to life but I discovered my horn is dead. No sound, not a peep. I went to check the fuses, but checked the manual and I would have also lost turn signals, etc if I lost the fuse. Anything else simple to check before I start pulling off tupperware or hauling it to the dealership?
Have you checked the horn relay to see if it is working.
Come to think of it I believe you are right. I would just jumper the horn directly to the battery and see if it works. If not the the horn has gone bad. If it does then start checking wires with a test light or meter.
Ya, it looks like it comes down to basic diagnosis techniques. I just was curious because you do not hear about any issues with stock horns.
1 - 15 of 15 Posts
