1 - 3 of 3 Posts
Thanks to all that responded to my original post. I finally got the drain plug loose. I used an impact driver ( set at very soft) and it came loose. I also did this when the unit was cool. I switched the filler plug and drain plugs around so that I could snug the drain plug. Does anyone know what the Suzuki part number is for the drain plug? I could also use the number for the filler plug as well. The only difference I see in the plugs is a magnet in the drain plug itself. There was very little gunk on the magnet when I drained the oil.
Great to hear you sorted it out. Go to Ronayers.com and looked it up in their microfich...should be able to find it there.
I have found MR Cycles Microfiche much easier to look at than Ron Ayers. You don't have to scroll left and right to look at the parts.
The best prices on parts are from JT Motorsports.
Hope this helps.
Dee
1 - 3 of 3 Posts
