1 - 14 of 14 Posts
Installed the OEM heated seat and heated grips today. The heated seat comes with the switch that installs in the dash. All the connectors are on the bike's wire harness, so everything is plug and play, at least they are on my 2013. Very easy install, took about 20 minutes. The heated grips are a little more difficult to install but there were no surprises. I did discover there are two other unused electrical connectors on the bike's wire harness in the same area as was found the connector the heated grips plug into. What these connectors would be used for I have no idea. I tested out the heated grips and they get very hot. I haven't had a chance to try the heated seat yet, it is 108 degrees today in Phoenix.
Was there anything to install in the seat? Is it pre wired for heat?
Discussion Starter · #5 ·
The seat comes with a back rest and prewired with the heat. The only thing you need to transfer from the old seat is the light.
What is the cost I for the seat and grips?
Discussion Starter · #7 ·
http://www.ebay.com/itm/Suzuki-Burg...Parts_Accessories&hash=item2ed2717784&vxp=mtr
http://www.ebay.com/itm/Suzuki-Burg...Parts_Accessories&hash=item258f8aba68&vxp=mtr
Above is where I bought both the seat and grips from. Bought them both on the 27th of May, they both arrived on Jun 5th, $449.95 for the seat and $224.95 for the grips. Both had free shipping and I'm glad because the box the seat comes in is huge and would cost a small fortune if shipping was extra.
Hmm.. I just put heated grips on mine for $20. Cycle gear had them on sale.
I use a Bunz-eze pad that retains heat for a couple of hours in the cold and also retains cold for a couple hours in the summer.
azccj,
Is the heated seat identical to the stock one in terms of shape/height/softness? Did you notice if it was any higher than stock? I heard that the heated seat on the 650 is higher than stock. Is it the same with 400?
Discussion Starter · #10 ·
azccj,
As far as I can tell the heated seat looks identical to the normal 2013-14 650 seat. I don't know anything about the 400 seat.
Heated grips
Just received a new pair of heated gloves from VOLT! Awesome, 4 heat settings, waterproof, wind proof, heated on both sides and cordless! What's not to like and cheaper than heated grips. www.voltheat.com
Nice.
1 - 14 of 14 Posts
