1 - 3 of 3 Posts
Which brand of heated grips do you use, and why?
Oxford, because they have a good reputation and are easy to wire up.
They have thought of everything, so you just wire the controller straight to the battery and it will switch off with the engine, as the battery voltage sinks.
They are quite thin in diameter - which I like, but if you like large diameter grips they are not for you.
I have no experience with other brands.
I bought mine at Cycle Gear for $19.95. They are printed circuit boards that glue to the handlebar and have a switch for two levels of heat. I use mine all the time in winter and they work great.
1 - 3 of 3 Posts
