1 - 4 of 4 Posts
my headlights both high and low beam quit. No voltage across the fuse, anyone got a clue? Also I managed to reach in and wiggle the wiring harness to the ignition switch and the clock stopped it restarted the next time I started the bike.
· Premium Member
It is possible the head light interrupt in the starter button has stuck. Try hitting the pass button on the left grip and see if the lights come on. If they do it is a good sign that the starter button is to blame. If that is the case spraying contact cleaner or WD40 into the starter button may solve your problem.
1 - 4 of 4 Posts
