1 - 5 of 5 Posts
Both headlights on my '08 400 are out. Everything else works fine. The bike starts up great, the brake lights, turn signal and dash lights work. The small bulbs near the headlights are on, but the headlights and brights do not come on.
1) If one bulb is out, does this kick out the functioning of both bulbs?
2) Should I start with cleaning the starter switch contacts?
I haven't checked any fuses yet. Is there a specific fuse for the headlights and is it located in the main fuse box?
Thanks for any help. Jake
I hope that's what it is since that tutorial looks awesome and now it will be easy! Great job with that. Thanks for your help with this. I'll post my results.
Drjbg - did you solve your headlight problem and how? My dim light will not come on though the bright works fine.
The OP hasn't had any activity here in seven years, so you likely won't get an answer from them.
Reactions: ducati14
1 - 5 of 5 Posts
