I have a 2012 650... white..I have 5200 miles after owning it for 13 months.
Curious more than anything else... the piece of panel that is under the brake lights that goes around from above the muffler to the other side had one side that came loose.. I didn't do anything to it.. it just came loose.. there were a couple of tabs showing the fit into the section in front of it that required that the tabs go in and be pushed up. I found a hole at the bottom that was obviously required to have some sort of screw or something threaded up to hold it in place.
I taped it so it wouldn't blow off and went to the dealer.. they said it was a push pin that had somehow come loose.. That surprised me.. I have seen other older Burgmans with that piece missing or taped on.. so what causes the push pins to fail like that? I really had done nothing, except maybe hit a pot hole or two from time to time.. I want to be sure that I check for that, if it's a chronic problem.. :?:
