My glove box latch (part attached to the bike) broke. The base where the metal rod is attached that the actual door latch holds on to broke on the ends. I tried abs glue and fiberglass (sheet) and it worked for a while. I then tried just epoxy and it worked for a bit shorter than a while. I'm thinking of cutting up the fiberglass into small(er) segments/pieces and mixing with the ABS glue, but ...
Any easy fixes?
Any easy fixes?
