1 - 1 of 1 Posts
A tip for installing the givi windsceen on the 650. When removing the old windsceen. pull the old windscreen off of the rubber grommets. Then pull the grommets out of the frame on the scooter using channel locks(pliers). Take a Q tip and apply dishwater detergent to the holes in the scooter frame in which the grommets were removed. The grommets should then be installed in the givi windscreen, but only use detergent sparingly. Then push the grommets attached to the windscreen into the holes in the frame. They will go in with little effort. Install the bolts into the grommets to hold fast the windscreen. This will make installation easier.
1 - 1 of 1 Posts
