OK I just purchased the Givi T435 hump bag. Nicely made and lots of room for rain gear, camera and other misc. stuff. Since I currently have both the 400 and 650, let me tell everyone that it was designed to fit the 400. The 650 is a little tight and crunches the bag so it doesn't fit cosmetically as well. The front portion can interfere with the key. I will still use it without hesitation since some of the trips I have planned will be camping I could certainly use the storage. However on the 400, it fits perfectly. They also make a rear seat type bag that I may buy as well. 47 cm X 30 cm dimensions.
I would like to find some kind of cover to protect the plastic in the hump area. I was wondering if anyone has come up with a design or source for such an item. It could be made of any dark coloured material.
I'm about to try some outdoor carpet, short loop, dark gray. I suggest going to a carpet place and asking to see their cut-offs. My local place gives me small pieces when I need just something small. I'll probably use snaps with the male end screwed into the hump plastic and the female gromet-like in the carpet. This way it can be unsnapped and cleaned when necessary.
Dave B.
4dthinker, you could try self adhesive velcro strips first, save putting holes in your burg, and see if that works.
If not, drill away.
I've used snaps before and prefer them. Any adhesive-backed solution I know of will eventually fail as the adhesive breaks down. You're right that a snap when removed would leave a little hole, but I've filled many before with epoxy. Black silicon would work too. The snaps use a #4 screw, so the hole is very small.
I'm thinking that eventually I'll get or make a hump bag. Carpet removed, the snaps would then hold it in place.
Dave B.
There are some photos in the gallery of similar setups, carpet, leather etc on the hump.
Take a look around in there.
Actually there is a strap on the bottom of the bag that wraps around from the bottom to the other side. It seems to work just fine. I think I'll use the bag in this fashion...it seems very secure and I'll use a bunch of black electrian's tape to prevent scratching the paint and plastic bits. I'll place a black sheep skin piece underneath the bag.
