I received my E55NT trunk this week and discovered than the release on the handle was too easy to release. You could release the handle by just wiggling the key. I called the dealer I purchased it from and they tried another E55 they had on display. It released the handle in the same way. They called GIVI and was told the the release for the handle on the more recent E55s and E52s was redesigned to make the handle release with less effort due to complaints and broke off keys from the older trunk's hard to release handle and that is just the way they are now.
Wrong. I took the locking/handle mechanism out and discovered that the small plastic latch hook that holds the handle in was not manufactured properly. I used a heat gun to bend the latch hook to the proper position and it works fine now. However, the newer handle release is easier to use than the older ones I had in the past.
