1 - 8 of 8 Posts
I want to upgrade (aka replace) the stock windscreen. I need to make the choice between the solid or adjustible Givi 266 models. My problem is that I was born short and stayed that way. I can see over the stock shield, I probably have an inch or maybe 2 of sight above the stock shield at the 50 foot distance.
I know the AF is adjustable, but not enough (from what I understand) to drop the top down low enough for me. Can I lower the mounting setup to get me the correct height? If I cut the top, will I loose the airflow?
If I cut the DT version, am I going to loose the airflow? I know others have done it, so it must work.
I want to drop the noise in the modular helmet, and add stability to the bike.
I sent an email to Givi, they have not responded. Now I need your help. What do I cut or modify to work for me?
I'm 5'5" w/ a 29' inseam. w/ the AF266 on my 400. In the lowest position, I can see over it quite well. It drops as low as the stock windshield.
Well, since the comments were unanimous,:rolleyes: I ordered the AF266 from Revzilla this morning.
I did get the answer from Givi. Talk about a quiet bunch. I asked several things about the AF266 and 266DT. Their complete answer was:
Hello,
The lowest setting on the AF266 would be around 27” in height.
From what I can find in my research, the stock screen height is 26", so the Givi AF266 should work fine.
I have now installed the windshield, and from my garage view, it is too tall.
I have only a couple choices that I see:
1) grow taller...don't I wish. Not fun being short.
2) modify the top screen bracket to cut off about 1/4" allowing the top to slide down a little more. Would gain about 1/2 to maybe 3/4 of an inch.
3) move the latching device down about 1 hole/roughtly 1 inch. That will gain me the amount that I move the latch down. I would probably pay to have this done so it is done right.
I suppose I could add an Airhawk to the seat to make me sit a little higher, that would add comfort too.
Where was that human growth hormon 45 years ago?
Exactly what I was thinking before I got to that part of you post. The only problem may be if you can still get your feet comfortably on the ground.
I am going to explore the ability to move the top screen mounting assembly down. It looks as there are 3 holes, 2 small screw holes and one larger hole for the latching assembly. If I move the top screw into the bottom hole, then I would need to drill two holes lower. That would drop the top screen to a very acceptable location.
If this proves to be a viable way of reducing the top height, I will look for the correct bits. I guess they need to be a different cutting angle on the bit for the acrylic.
Don have you ridden your scooter with the new screen on yet? If you can see over the screen by sitting up a little straighter it may work out ok. In my opinion a rider needs to be able to see over the windshield when it's raining and in certain lighting situations. I assume you already know that and that's why you want to be able to look over it.
Discussion Starter #8
If the top screen was a half inch to an inch lower, it would be great. I could feel the effect of the wind being pushed up. I can still see the colors in the plastic, I'll get used to that.'
Going on a longer (all be it) city street drive with a local scooter group. Hopefully I'll be used to it by the end of the ride and be satisfied with the position of the top screen.
If not, there is a shop about 5 miles from home that may be able to help me.
Got my Bestem 929 top box wired up with the brake light flasher today. Now when I stop, three sets of lights flash.
1 - 8 of 8 Posts
