1 - 4 of 4 Posts
Manual calls for 10W-40 motor oil with at least an SF or SG rating. I use the same 15W-40 Rotella T4 that I run in the engine.
80-90 GL5 gear oil assuming you refer to the final drive oil engine oil as per the Buffs recommendation
I would accept both and use whichever is more handy to me. When I open the final drive box, I found just 3 gears with shaft and run on shaft bearings , bathing in the lubricant. BTW, be careful of the breathing hose as water can get inside the box through there. Thus, changing the oil regularly is also necessary.
1 - 4 of 4 Posts
