1 - 11 of 11 Posts
Does 100% gasoline make up for it's more expensive price over E10 gasoline? Here in port angeles the e10 gas is 2.99 a gallon and the 100% gas is 3.95 a gallon. Does the gas mileage increase justify paying an extra 96 cents?
The mileage is a little better but it's not going to make up that much difference in price.
I've run real gas in two tanks of my V-Strom 650. Both times I exceeded 70mpg for the tank. I usually get 64 on average for the alcohol gas. The price however doesn't justify 5-6mpg difference with real gas at $3.99 and alcoholed gas at $2.80 locally. I only got real gas when that was all I could get when right at "bingo" fuel. However in a carbureted small engine like a 125 scooter or lawn equipment it can solve alot of problems.
Does the alcohol cause any problems in the Burgman's engine?
No. Any fuel system and engine produced since the early 90s will not be adversely affected by E-10. My daughter's '93 Toyota 4-Runner has been drinking it for 10+ years and over 140k miles. My '98 SL500 runs fine on the swill...
We pay $1 more a gallon for it too. I use 100% gas in my car and my scooters that I don't ride at least one or two times a week. The scooter I ride daily I just use E10 with no problems except for a two - four MPG loss.
I found the difference is close to 10%.
So $3.00 for e10 =$3.30 for real gas.
If I could get 100% gas for 10% more I would use 100% gas as my only gas no matter how much I ride/drive. But I won't pay $1 a gallon more for my daily ride. like I said above I'll only use it in my vehicles that sit around without being used.
The 100% gas stays fresh a lot longer than the E10 crap even without putting Stable or fuel treatments in the 100% gas.
In my neck of the wold the only non eth really close enough to use for me is very expensive 92 octane.
I haven't used it lately.
There is a place that sells 87 that's a bit out of the way that's not too insane for price (~15% higher) that I tried out for a few tanks on my 06.
The 06 does not have computer controlled idle, or an 02 sensor so it'd be different than newer bikes.
On it, I found that using a decent grade (normally shell, or costco) 87 was a bit lower over several tanks, but was within range of the generic 87 non-eth I can get. In no way did it come close to justifying the cost, but I do use it if I'm in an area where I can find it.
Of course if I know I'm going to have to store the bike for an extended period (very rare) I'll go out of my way to get non-eth in there since eth-gas does break down a lot faster than straight unleaded.
I use E10 87 octane all the time in all my vehicles with absolutely no problems. I do use an additive in my Burgman, though. I recommend Regane All-in-One additive.
Don't forget the cost of additive to keep the E10 from separating .
Not if it has a carb! You will get a build up of crap with E10. Of coarse very few bikes still use carbs but there are a few.
1 - 11 of 11 Posts
