I refuse to pay $15.00 for the OEM Oil Filter that used to cost $7.00, so I started looking for alternatives.
There seems to be a good number of choices out there and they seem to have been tried and used by a number of 650 owners with great success.
I opted for the EMGO 1055660 in the end based on a few recommendations from trusted parties on BUSA and other sources.
This particular filters seems to fit a lot of different Suzuki models and has had a good track history.
I originally bought one locally from my dealer at full MSRP for $5.95 so I could try it out. I then order 5 of them from Partzilla for $3.75 each plus $6.95 for s&h which brought the unit price to $5.14 each.
I change my oil every 4k miles now so this seems to be a very good alternative for my needs.
As usual spend your money on what you think is the best solution for your ride.
I put together a quick FYI doc which you can check here with lots of pics and a video which I will be adding soon:
FYI - Emgo 1055660 Oil Filter
It even fits the OEM Oil Filter Adapter / Wrench that I use to remove / install the OEM oil filter.
I only have a few hundred miles on this filter but no leaks or unusual compression issues as the dealer tried to warn me about when I place the order for the cheaper oil filter.
A few pics as usual with the video to follow soon:
