1 - 3 of 3 Posts
I have a 30 amp fuse on my main power line to the battery. What size fuses should I use in the fuse box for the driving lights, and the usb outlet? Thanks.
Look at the device you are hooking up for peak amperage rating to select the right fuse "size"/rating. It is also usually recommended in the directions if the device came with any.
1 - 3 of 3 Posts
