1 - 7 of 7 Posts
Been searching on this forum and others ,trying to find the location of the fuse box and where is it located ? Also wondering are they the standard size fuse or the mini fuses ? Have a 05 400, also the part # for the headlight if someone would have that info??
Thanks to all for the info ..Have put about 700 miles in the last 2 weeks and really enjoy the 400 .
· Premium Member
The fuses are behind the panel that is between
the windshield & the headlights. The screws
that hold it in place are seen from the drivers side,
in the corners, recessed next to the windshield.
After removing the 2 screws, pull the panel
straight forward.
OH one more question, on my 80 Honda cm400t the front amber lights burn when the engine is running and of course blink when turn signal switch is used.
I noticed mine do not burn on the Burgman . Well at least the front ones don't but the rear lights do.
So are the front ones suppose to burn or not ??
Thanks again.
Thanks again.
No, they are only turn signals.
Re: fuses, here's what runs what:
1 - 7 of 7 Posts
