All of us AN650 owners have had to get used to the LCD fuel level bars:
1st bar) almost 100 miles.
2nd bar) around 125 miles.
3rd bar) about 155 miles.
4th bar) about 185 miles.
5th bar) get gas!
5th bar blinking) That had better be a gas station ahead.
But wait... We want a more precise readout, like this:
1st bar = 1 gallon used.
2nd bar = 2 gallons used.
3rd bar = 3 gallons used.
4th bar = 3.5 gallons used.
5th bar = 3.75 gallons used.
Introducing the BurgyFuel Module.
Its programmed to do analog-digital-analog mapping from the gas tank sending unit (variable resistance) to the sending input at ECM.
BurgyFuel Module processor re-interprets this resistance into precise fuel remaining values to make the appropriate bars blink, then each bar will go out.
The BurgyFuel Module lets you know exactly how far you have to go and how much fuel is used, including more realistic mpg (or litre/) calculations before filling up.
Use one of the tripometers as elapsed distance compared to spent fuel bars - It’s easier!
There are several fuel used/remaining ranges available in the BurgyFuel Module, including litres per bar. A jumper chooses which one, upon installation.
BurgyFuel Module is very reliable and doesn't adversely effect your Burgmans circuitry because its (low-power & fused) circuitry only senses and outputs highly isolated resistance!
Installation is not messy and does not involve contact with fuel or other fluids.
There’s a simple connector that reconnects the Burgman ECM to the sending unit again to make your Burgman go back to the stock fuel readout if the BurgyFuel Module is ever removed.
Need a real-world fuel readout for your Burgman AN650?
The BurgyFuel Module is $55.00 and that includes U.S. shipping and U.S. instruction booklet.
Allow 8 weeks.
5th bar) get gas!
Allow 8 weeks.
