1 - 8 of 8 Posts
My fuel door is busted at the little spring loaded bracket that holds it open or closed. Partzilla has 'em for $36 but thought I would try here first. Mine is a 2007 non-Executive. Anyone out there "can help a brother out?"
I did not realize I was posting in the general forum. My bike is a 650.
Discussion Starter · #7 ·
Sorry--haven't checked the forum in a while. The black hinge part is OK, its the little tabs on the fuel door itself that have failed. actually, only the lower tab. I tried JB weld and even plastic welding, but have not been successful. It will hold for a day or so then I guess the spring tension if too much. Not sure how a new door would be inserted onto the hinge, but there must be a way or they would not sell the pieces independently.
KMCampbell--I will give it another go with the JB Weld. That's marvelous stuff.
It's a white door.
Thanks to all for looking.
It's a white door.
You might try a solvent based adhesive for ABS.
1 - 8 of 8 Posts
