I got the seals, but now I can't take the piston out. It says in the manual to use 2 special tools. Anyone know how to take it apart without those tools? Thx.
I've never taken mine apart so I looked at the manual to see what you were referring to. I assume you are talking about the T handle and Attachment A.
The T handle is just a drive to fit the attachment and a 3/8 rachet would do. That's what it appears they are using in the picture in the manual.
The attachment A just looks like a fancy spline drive bit. A torx bit has half as many engagement points but would probably be easier to find than a spline drive and should work. I checked the largest torx in my set (a T50) and it was a loose fit on my 06 400. You would need a larger size than that, probably a T55. I did a quick google search and found this one at Autozone. http://www.autozone.com/autozone/ac...ter=1&itemIdentifier=864639_0_0_&target=shelf You should be able to find them at other places.
I've done my seals a few weeks back, looked into the attachment A but from looks of it is is just a cone object that stops the inner part from rotating when removing the bottom bolt. I just used a pipe and wrapped enough electric tape. The tape hold the inner pipe while removing the bottom screw with the impact.
1 - 8 of 8 Posts
