1 - 17 of 17 Posts
Wow! That took alot of work!
What exactly is purpose of those two extra wheels?
Some people can not hold a two wheel motorcycle up at a stop. So a trike helps them still ride. Some will just say "Get a Miata" but that is not fair.
Give me the choice of a 1 wheel up front and 2 wheels (1F2R) in the rear OR a Jaguar F-Sport Convertible, I'll ride the Convertible with the top down most dry days.
But a proper 2F1R I'll take over almost any convertible.
But this "Trike" that the OP has is a 1F3R and in my state is 4 wheels on the ground.
Reactions: airhead83
Of course I understand that some people have mobility problems or simple they cannot handle two wheels, so they choose to ride trike, but this is not trike this is"quike", adding two extra wheels on already prone to failure cvt is by my opinion too much, as two more wheel for sure create lot of drag,even creating proper trike from burgman 650 has questionable reliability
I've seen an older Gold Wing running around in my area with those Outrigger style extra two wheels. It still is 'powered' by the main rear wheel. I guess you just have to LEAN a lot when cornering, and muscle the handlebars, like any other rear wheel trike rig.
We don't see many of these this side of the pond, but my understanding is that there is a element of "give" in the outrigger wheels' mounts. Such that a small amount of banking is possible.
The axles are torsion sprung, I think.
OP can perhaps confirm?
Tire Wheel Automotive tire Hood Automotive lighting
Font Rectangle Parallel Schematic Auto part
Discussion Starter · #16 ·
Wow alot of interesting conversation and I will try to address all questions. I added the extra 2 wheels because the wife won't go on road trips without. I ride as often as the weather and my RA allow and yes phase 2 allows for more riding. As far as handling, it does handle just like a true trike, which means the turning is different than just 2 wheels. First time I took her out it was a bit of a shock how different the turning was, however I plan some short trips, as weather allows to get used to it before setting out for a week with the wife.
them houses,, if you drop yer viagra pill inna kitchen, it's gonna roll alla way to the garage!
1 - 17 of 17 Posts
