Hi Guys,
I don't post but have been an avid reader of this forum for some time and now hope that someone can help.
I have a 2006 Burgman 400 but the fuel injected version (not the new shape 2007 +...).
The bike has covered about 5000 miles and runs perfectly except for one problem.
When I try to start the bike sometimes the FI light and 'key light' will start flashing and the engine will turn but it will not fire or start.
The interesting things is that this ONLY happens when the weather is wet and bike has been ridden or standing in the rain - or when there is heavy fog. In sunny weather the bike starts absolutely perfectly all the time. As soon as there is a rainy day, this problem rears it's head again. If I kick the side-stand up and down then eventually the light stops flashing and I can start it, but the bike lurches forward slightly as if too much fuel. If I leave the bike for a day or so, I can start it again. The bike will never stop while the engine is running - once started it runs great.
My local Suzuki agents have not been able to fix or identify the problem and have cleaned all switch gear and sidestand switch etc but the problem still happens.
Sometimes when the bike is dry and working, I will take a hose and try to wet under the front cowling, the sidestand switch etc and try to emulate the problem but it will still work. The as soon as there is wet weather again the problem starts again - so why not when i personally spray it with water? Also, if i try to start the bike and I slightly stall it, then the problem will start but it's usually okay when i start the bike first time.
Could it be condensation somewhere? At my wits end with this!
Would appreciate some help if anyone knows?
Thank you.
James
Thank you.
James
