1 - 3 of 3 Posts
Got this code on my '03 650 today. It relates to the fuel injector on the second cylinder. Does this mean the injector is bad and should be replaced, or just that the injector is dirty/fouled/plugged and needs to be cleaned? I put some Sea Foam in the gas, just in case.
When I got the FI indicator, my engine bogged down just momentarily. Ran fine after that.
I would probably put a lot of seafoam in the gas and run that tank out and then disconnect the negative battery cable for 20 minutes or so to reset everything then see if it comes back on. If it does I would guess it's either a bad injector or faulty wiring somewhere. Check all the wires and plugs going to the injectors for corrosion or bare wires or something obvious and it it all looks good it's probably the injector itself.
I think Ebay or the classifieds here will be your best bet, I think they are 150+ ea new at the stealership
1 - 3 of 3 Posts
