hi all,
just purchased a genuine spare key for 2006 Burgman 650, and key turns but wont start (F1 starts flashing).
Don't know what to do next
Treacle1
The European Burgmans have the SAIS (Suzuki Advanced Immobilser System) with a transponder in the key that must be "matched" with (programmed to be recognised by) the ECU.
I did not think North American models had the anti-theft system, however as you did not specify your location--who knows...
I'd suspect that it's the SAIS immobiliser. Forget how long immobiliser have been mandatory in OZ.?
The head of the new key needs to have a chip inside which needs to be paired with the master key (red key). Most manufacturers provide a red master key & a pair of slave key's - the red master key is important & manufacturers recommend putting it in a safe place (not for daily use). The red master key is used to code a new slave key hence why any new key has to have a chip inside it.
It's possible to reverse engineer a slave key to the immobiliser transponder or another slave key using a special electronic device - but it's not cheap...
Any reputable locksmith would check any automotive key that has a non metallic head for the presence of an electronic chip before cutting a new blank.
Hi
I believe the burgs have the security system installed in Oz. I have owned a 2003 650 previously and a '14 burg currently. Both had it
