1 - 2 of 2 Posts
Error Occurred While Processing Request
File not found: /fiche/300_0346/wiring_harness/wiring_harness.cfm
Please try the following:
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; iebar; (R1 1.5); .NET CLR 1.1.4322)
Remote Address 68.229.235.11
Referrer http://burgmanusa.com/forums/viewtopic. ... c&start=25
Date/Time 23-Jul-05 10:47 PM
Stack Trace (click to expand)
coldfusion.runtime.TemplateNotFoundException: File not found: /fiche/300_0346/wiring_harness/wiring_harness.cfm
at coldfusion.filter.PathFilter.invoke(PathFilter.java:77)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:47)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:52)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:35)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:43)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.CfmServlet.service(CfmServlet.java:105)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:252)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:527)
at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:192)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:348)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:451)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:294)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
That error is from a link pointing to an outside source at :
http://www.ronayers.com
They've probably either updated the fiche or redesigned the site to where that link is no longer valid.
1 - 2 of 2 Posts
