1 - 2 of 2 Posts
i am attempting to add a cool hitch cover with running light, brake light and turn signal light .
i hooked up the day light and brake light from the connection to the brake light and they work great. however i am attempting to hook up
the turn signal light up and i am not getting anything. my tester when
grounded blinks when the signal is on. the hitch light does not.
the hitch comes with a ground , day light and left and right brake and signal light on on wire. 4 wires that is.
i grounded the hitch light wire, ran the day light and the brake light however
i am having problem with the signal light hook up.
any help would be appreciated.
thank you very much.
when it is hooked up i will post a pic.
kris
I'm no electrician but I can do some fairly easy wiring. Looking at the shematics in the back of the service manual there are 4 wires used for the tail light assembly. Just so I don't miss anything and not sure what you need I will try and be thorough.
The three common wires to both sides are:
Brown
Black/white tracer
White /black tracer
Right turn light is Light Green
Left turn light is Black
If I'm reading the schematics right The left turn signal is controlled with the Black and Black/white tracer
The right signal light is Black/white tracer and light green wire.
Hope this helps . I'm not really sure what you are looking for. Just thought I would try.
1 - 2 of 2 Posts
