First thing to check is the fuses, especially the signal fuse. If it goes a lot of things on the bike will not work. If the fuses check out good then the next step would be to check the ignition switch to see if it has failed.
That sounds more like a bad battery. You may want to have the battery tested.Jscottbennett64 said:I will check the signal fuse, thanks. And when I turn key, the under seat light went right out.
+1, sounds like it has voltage but not current like a bad battery. After you replace it make sure the charging system is keeping it charged too.Buffalo said:That sounds more like a bad battery. You may want to have the battery tested.Jscottbennett64 said:I will check the signal fuse, thanks. And when I turn key, the under seat light went right out.
Good deal, you did check the charging voltage after I hope and its ok? Would hate to hear it dies again down the road.Jscottbennett64 said:Thanks MJRand Buffalo. I replaced the battery, and it runs fine now.
I assume you are talking about the fuse box behind the panel to the left of the main glove box. Find the cover with the work "FUSE" stamped on it. Look on the left side of that cover and you will see a small tab. Pull that tab out a little and lift the back side of the cover. It will hinge forward toward you and reveal the fuses under it.billmusser said:I ound the fuse box how do i open it .cant figure it out and want to be very careful not to break tabs .If I ever need to replace a fuse
