Ok guys here is the story but short. I was changing my gas tank due to it got rotten for some reason and the fuel pump,,,after I put the new parts,,,it was late and I did not mounted all the plastic covers back,,i left the scooter outside and forgot my Pitbull was outside,,,the next morning I found the **** dog ate thru the main wiring harness and most of the connectors...So I bought a new wiring harness and spliced all the wiring....The scooter starts up perfectly with absolutely no errors and runs perfectly....
What I found so far is that both of the brake switches have constant 12 volts running thru them exept when the switch is pressed....Look guys I don't want to mess around with all of the connections I made since the scooter is running perfect. all I have are running lights and when I hit the brakes the running lights go out...\
I was wondering if I could just make another circuit for the second filament of the bulb,so that it goes on when I hit the brakes leaving both the regular running lights that are ON when the bike is running and the added second filament.
The brake switches normally are closed,so there is a constant 12 volts in the circuit until you press the brake level,,,,,,How in the world can I make this happen? Any ideas will be gladly appreciated.......
