1 - 9 of 9 Posts
I have had my Burgman 400 now for less than a week and really enjoy it. I have noticed that when running at low speed for an extended amount of time, a small motor (pump or fan?) runs even if I shut the engine off (as long as the key is on). I am assuming it is temperature related and runs when the engine gets hot.
Any idea what it is?
Thanks!
Yep, the fan.
When this happens, you should see that the temperature is quite high on the indicator, but after a few moments hearing the fan, you'll see the temperature going down (and the fan will eventually stop working).
That's what a happy burgman does.
Thanks for the replies. After I posted I forgot that it is a liquid cooled engine and that it has a radiator... Anyway, I took it to work today for the first time and now I'm looking forward to going home ... (in more ways than one :wink: )
Interesting...
I've got 8k miles, and have never, ever heard the fan come on. Nor have I ever raised the temp more than halfway up the indicator. I always assumed that the fan was coming on at that point, but was so quiet I didn't hear it. Apparently, I've just never warmed her up enough.
So, at what point on the temp gauge should I expect the fan to kick in?
Hi Lapine Rider,
My temperature guage never varies from around the half-way point either. The only reason why I thought it was temperature related is that I can hear it after stopping from a low-speed (< 15 mph) run on a dirt road or after a lot of stop and go driving and then long idling. Again, the temperature guage doesn't really change much. (I'll have to pay closer attention the next time)
I never heard it at a stop sign or red light in normal driving. My bike is a 2005 AN400 K5 if that helps. Maybe the thermostat is more sensitive in my bike... The fan is very quiet and I am pretty sensitive about sounds. Shutting the engine off via the kick stand or engine cut-off (and keeping the key in the on position) allows you to hear it better.
Hmm. I work in a stamping plant and am about half-deaf. From the first post I got the idea it was pretty loud. I'll experiment and see if I can't pick it out in the manner you suggested.
Thanks!
On mine, the fan starts a little above halfway on the indicator. This happens only:
-when it is hot
-when you get stuck for a long moment in traffic
You do hear it as a driver. The passenger usually does not notice it, except if you mention it. But it is much more quiet than these cages' fans, that sound like they want to take off.
Lapine - get the engine heated up and use the engine kill button while keeping the key in the on position. You'll probably hear it - but it is relatively quiet...
1 - 9 of 9 Posts
