1 - 3 of 3 Posts
Hello
My name is Stefan Dutu. I am from Romania.
I bought few days ago a Burgman 650 executive. from 2005.
I have some problems with it. The FI light is on, so i think I have some erors.
The main problem is that on automatic mode the high speed in 60 km /our and on manual mode I can change only first and second gear.
Do you know what I have to do? where shoud I start?
Thank you for your advise.
congrats on the 650 and welcome to the 650 family,
you should try and figure out what F1 code you are getting by placing the scoot in dealer / diagnosis mode.
the plug is located under the seat where the main and cvt fuses are, the picture below should make it clearer.
you can check my burgman center for more details on the F1 Special Tool if you need to, and for the F1 code description if you don't have a service manual.
you may want to clean the center stand and side stand switches to make sure that they are not sticking, they are often the first culprits to cause the scoot to not shift up past the first gear.
all the best.
Thank you. I saw a discution about how many wire shoud it be there . I will check tomorow.
Do you know witch model of burgman is it?
1 - 3 of 3 Posts
