1 - 4 of 4 Posts
I am trying to remove the drivers butt stop, took out the two larger bolts/screws ok.
Moved the butt rest forward but the two small screws in the mounting rods are in the way. Tried to remove them , but all they do is turn and do not back out ??
Help ??
Doug
You do not have to remove the two large screws, just the two small ones in the adjusting rods. Sounds like the threads are stripped on the small screws. Grind them off with a dremel tool.
And put the two big screws back in before you pull the butt stop out. They hold the adjusting mechanism in place.
OOP's too late :eek:
I got the two small screws out with a pair of small vice grips.
Then removed the butt rest, and reinstalled the two large screws.
Thanks,
Doug
1 - 4 of 4 Posts
