Sorry, I couldn't tell you the dimensions. You can get an idea though by looking at this picture from the Gallery. The DP weight is turned so the long end is facing towards you.
http://burgmanusa.com/gallery/Daboo/Clutch/
You can also get an idea of the size difference with this shot of the DP weight sitting on top of the OEM roller.
Gas mileage seems to be about what I would expect for the conditions I'm riding in. We have been hitting some very strong winds recently, and that would make an impact on gas mileage, even if I hadn't changed the weights. I have to admit, I'm having fun twisting the throttle more than before because the response is so quick. So that will have an effect as well.
Regarding gas mileage, I think you can make a couple assumptions since each of us ride in different areas. If you're riding on city streets in stop and go traffic, you weren't getting good gas mileage anyway, and the DP weights won't help you. You'll probably lose a couple mpg even. The reason is that the rpms are a little higher than before.
If you're up at freeway speeds, I think you may find your gas mileage improving. Before with the OEM weights, I would just gradually accelerate. I'm still getting used to this but it seems the best way to accelerate with the DP weights may be to hit the gas more to accelerate quicker to 70 mph, then back off on the throttle. The rpms jump up as you're accelerating, but when I back off the throttle, the rpms drop off considerably and then tend to stay there, even as the grade increases or the winds pick up. So the trick seems to be getting into that "higher" gear quicker, if you want higher gas mileage.
Chris
Chris
