1 - 8 of 8 Posts
Hi,
What is the difference in a DOHC and a SOHC. I have noticed some motorscooters have a DOHC while the Burgman 400 has a SOHC? Is one more efficient than the other?
scootervan
SOHC = Single Overhead Camshaft and DOHC = Dual Overhead Camshafts.
In general the SOHC offers more low RPM grunt while the DOHC affords more effecient upper RPM power.
The DOHC is generally more effecient however it is a bit more complex.
SOHC is usually used when you have only one intake and one exhaust valve per engine cylinder and the DOHC involves manipulating more than just one intake and exhaust valve per cylinder.
just a quick nutshell overcap - im willing to bet better typists can add quite a bit more to this explanation.
DOHC setups use a seperate cam for intake & exhaust valves. Most DOHC engines use two intake & two exhaust valves per cylinder, though there are some DOHC setups that use a single large intake & two smaller exhaust valves. The OH indicates that the cams are located in the head(s) of the engine rather than being located in the block above the crankshaft. This allows the lobes of the camshafts to bear directly on the valve stem(s) eliminating the need for lifters & pushrods & allowing less lash & slop in the mechanicals of the engine, this leads to better efficiency.
SOHC engines use a single cam in the head(s) to control both the intake & exhaust valves, typicaly only one of each per cylinder.
Any gasoline engine is nothing more than a big air pump, the more air that can be run through the system at a time, the more power that engine can produce. Multiple valve setups allow more total surface area for the air to flow through, so typicaly these engines can make more power, usually in the upper rpm ranges as Pete describes above.
Regardless of SOHC, or DOHC, either is superior to the old pushrod configuration as far as efficiency goes. You eliminate a lot of valve train parts and slop.
Mostly referring to auto engines. Do any MC engines currently in production use a pushrod design? I suppose at one time they must have, but I know very little about 4 cycle MC engines except the Burgman.
Harley's V-twins still use push rods & a single internal cam.
The big Yamaha's also use pushrods, as do a few others. Pushrods limit the rpm that can be attained from an engine, but reduce the height of the engine. In big twins that want big torque, high rpms are not required - so they work fine for them.
Regardless of the number of valves they are operating, the biggest advantage to dual overhead cams as opposed to single overhead cams - is that the intake and exhaust timing can be totally independent.
Many single cam engines have stronger bottom ends - but that's probably related to having less valve area (ie: fewer valves). More valve area normally equates to more horsepower, less torque.
This is just personal opinion. but when an engine gets as small as a 400 cc 1-cylinder, in a scooter-type application where performance is not the only factor to consider, I think SOHC is superior. There is less less cost up front and, even more importantly, less to go wrong. If there were a significant MPG difference involved (I suspect there is none, but don't know) then I might feel the additional complexity is worth it. But, depending on the amount of MPG gain, I also might not. I simply do not like needless complexity in things mechanical. It gets you every time, sooner or later.
The Yamaha Majesty 400 uses DOHC, for what it's worth. I've noticed I have a lot more low RPM power than the Majesty does. From a stand-still, I leave the Majesty in the dust with my B400.
1 - 8 of 8 Posts
