No, the blowouts were during the mounting of the tire. The key is SLOW, allow the tire bead to stretch a little over time to fit the MC wheel.
What happened to me was with a VeeRubber tire. The changer guy tried to rush it with really high (>100 psi) air pressure and the side wall of the tire failed. Well, duh. It is normally 35 psi maximum rating psi. Trying to JAM the tire quickly on the rim will not work.
Once you have the tire properly mounted I expect about 15k - 20k before needing change. Keep the tire balanced, etc. I think the real key is the huge tire adhesion area, and the water discharge tread design. BUT I also feel that you can not be an agressive rider and do the CT because it has very limited sidewall tread and is NOT meant to be ridden anywhere but on the flat tread area, i.e. stay upright or don't do the CT.
On a trike the tire should perform very well because you are not leaning the bike at all, or very little. I think that the larger tread adheasion patch will suit a trike configuration very well. However, like all unauthorized modifications "you are your OWN warrantee station"
I rode to work first day on my Potenza today and it was like floating on a cloud it was so smooth. I had forgotten how really fine the ride can be. I even went back to town (40 mile round trip) for some components for work during the hottest part of the day just to see if the 20* hotter middle of the day (morning 70*, middle of the day 90*) was going to make any difference. Not one bit, just as smooth this afternoon as this morning, and just as smooth at 5 p.m. (about 80*) as the other 2 rides. So cranked on 80 miles today and it was really a fine ride all day. Let's see, getting payroll time to go ride your scooter for an hour, not bad eh?, but someone HAD to go get the parts, hahahaha.
Bob Weis
