Abner did you purchase the L brackets or make them?You have to use shorter M6 bolts. The L brackets fit tight against the engine case. The cover bolts are too long.
These are used to hold library stacks together. If I had to make them, I would probably buy a small piece of angle aluminum, and proceed from there. I can post a close up photo of an empty bracket later.Abner did you purchase the L brackets or make them?
I was involved in this thread with a scraping type noise, thought you should see if yours is similar. In short, use the center stand, engine off. Roll the rear wheel by hand, forward and backward. Scraping sound? If so definitely read up on this thread (especially near the end).One thing to add, when im on the bike with it off and im moving backwards, I can hear some scraping type sound it seems coming out of the CVT
Wow, good call, that seems to be the sound and from what im seeing my guess is that it is the needle bearing,,,,I hear its an easy fix, where is the bearing located exactly? DO I just need to grease it or full relacement? Id like to inspect it first,,,thanks man!I was involved in this thread with a scraping type noise, thought you should see if yours is similar. In short, use the center stand, engine off. Roll the rear wheel by hand, forward and backward. Scraping sound? If so definitely read up on this thread (especially near the end).
How urgent is fixing this needle bearing or wheel bearing?
Hello good people. I just bought this 09 Burger (6200 miles), haven't even riden it yet and discovered this wheel noise from the REAR wheel. I'm planning a 1,000 mile trip home from where I bought it. Do I need to deal with this before the trip or can it wait until I get back? Edited to add...www.burgmanusa.com
It’s a lot of work to get in there, and I would certainly replace it. I was concerned about safety, imagining that thing seizing while I’m on the highway. I wanted to know it was good. I did not have to open the clutch assembly. I was looking for what made the sound. My finger inside rotating it acting as the shaft did not like the slight roughness.Wow, good call, that seems to be the sound and from what im seeing my guess is that it is the needle bearing,,,,I hear its an easy fix, where is the bearing located exactly? DO I just need to grease it or full relacement? Id like to inspect it first,,,thanks man!
I will, can you post a pic of exactly where this needle bearing is?It’s a lot of work to get in there, and I would certainly replace it. I was concerned about safety, imagining that thing seizing while I’m on the highway. I wanted to know it was good. I did not have to open the clutch assembly. I was looking for what made the sound. My finger inside rotating it acting as the shaft did not like the slight roughness.
Extracting and replacing the bearing from the assembly did not seem like something I was equipped to do so I got a mechanic to do it. Report back on your results please.
Item 1, Needle bearingI will, can you post a pic of exactly where this needle bearing is?
Totally. If this was a preventative maintenance procedure, sure. To fix a problem? Not the approach I would take.re packing and greasing is like re training a girlfriend, not worth the effort when new ones are available
A "correct" rear rear pulley service, requires full disassembly (like in the diagram in post #30 above) + cleaning, inspection and correctly regreasing, not saying you need to replace/remove all the seals, bearings, etc.. but at least replacing 15yr old grease would help. Also having pulleys apart, allows you to sand/scuff pulley faces to remove shine, grooving and ridges, helps you New belt break in better.Hey thanks, so Im seeing this right, if I get the clutch off this bearing just sits on the back side of it? I dont have to disasemble the clutch but just remove it to get to it,,,,,is this something that can be repacked and greased, or just replace it?
I want to be clear that I’m speaking from intuition when I give advice here, not expertise. For me, I wasn’t servicing the assembly, I was just scared of that noise and wanted it to stop.A "correct" rear rear pulley service,
As much as a PITA it is, zrx is correct, if you are going to do it properly the entire CVT need to be disasembled and inspected then delt with, its the only real way youll ever get a true visual on what the tranny is doing AND ensure longevity and proper performance, I believe many of the maladies that riders have is that they dont fully inspect the bike and its not easy to be a real good tech, you have the take the time and have the desire to do it, many people neglect their bikesA "correct" rear rear pulley service, requires full disassembly (like in the diagram in post #30 above) + cleaning, inspection and correctly regreasing, not saying you need to replace/remove all the seals, bearings, etc.. but at least replacing 15yr old grease would help. Also having pulleys apart, allows you to sand/scuff pulley faces to remove shine, grooving and ridges, helps you New belt break in better.
The "Vespa Motorsports/Robot video" I linked on previous threads/post, tells you all about it, did you look at it, it?, specifically explains at the 12:30 minutes about rear inner pulley bearings, etc.
Just got a 2008 Burgman 400, some questions
"IF" any of the bearings feel rough/bad (1+3 in diagram), I would replace both. there's info on how to change them here, Variator Inspection & your feedback
You can also use a hammer and drift to knock out old bearings(not to install), 1st, "displace/move" the internal ball bearing snap ring out of groove (could be a challenge
), push ball bearing, against needle bearing then drive it out. BTW the needle bearing is a Suzuki proprietary size an $$$, the ball bearing is a common 6904-2RS, use it instead of oem and leave the bearing seals in place, it will last a lot longer than OEM part.
A lot of this info is kinda repeat of links already posted
This is what a typical full CVT service breakdown looks like ...
