Suzuki does not sell any pulley repair and/or seal kits and Afaik no aftermarket are available in the USA. Any part you may need will have to be purchased individually from a vendor, like Ron Ayers, etc.I should have a Driven Pulley seal kit, yes ?
Is there a Variator Seal kit ?
Are those Seal kits + any pulley hard parts (pins, etc) Suzuki OE from Ron Ayers, only ?
We have an echo in here.don't overthink it, just open the CVT and have a look.
Perfect advise, thx.Suzuki does not sell any pulley repair and/or seal kits and Afaik no aftermarket are available in the USA. Any part you may need will have to be purchased individually from a vendor, like Ron Ayers, etc.
The "kits" for different services, that "Robot" mentions, is a option offered on Piaggio/Vespa products, probably because is smart, not to say, way cheaper than Su ..
Replacing the seals on the rear pulley is probably a good idea, not so critical on variator, but wait until you see the condition of seals( did grease leak out, on clutch, etc), guide pins, etc., is mostly a judgement call on guide pins, etc., like shown on video, was there enough or goo grease on them ?, surface wear, play, etc.
All-Purpose Automotive Grease | • Reliable lubrication over wide temperature range -50 C (-58 F) to 246 C (475 F) • 75 % reduction in torque need at -40 F (-40 C) 1 |
Wide Operating Temperature Range | -40C (-40F) to 150C (302 F) |
Excellent Resistance to Rust and Corrosion | • Longer life of bearings and chassis lube points when exposed to corrosive environments |
Outstanding Structural Stability | • Provides effective lubrication over extended periods of time |
Exceptional wear protection under heavy loads | • 20 % Improved wear protection 2. • Provides bearing protection while cornering and other conditions where bearings temporarily experience heavy loads. |
Excellent resistance to water wash | • 40% better resistance to water wash out3 from heavy rain storms or exposure to high amounts of water. |
Improved grease bearing life | • 3X improvement in grease bearing life4 |
This product meets or exceeds the requirements of: |
NLGI GC-LB |
According to your posted info operating temp max is 150C (302 F)Temp range for Mobil 1 Syn Grease is -58 F to 475 F
Ok, TY noted.According to your posted info operating temp max is 150C (302 F)
A running cvt/clutch can easily exceed that.
You can find Lucas, red and tacky/ red/white tube or tub at most auto parts or Big Box Auto Parts, 540F max temp/drop point and compatible lithium complex, for $10 or less, do not buy/use Lucas green grease. BTW, again that Mobil 1 isI live in a small town, stuff like this really throws you cause inevitably, the 'super _' stuff you need is in Dallas FW, 3 hours away.
Or maybe not....I'll dig into that thread. Maybe we have local options.....
It’s not a discrepancy. max temp and max operating temp are 2 different things determined by different criteria.This part is confusing to me: Why the discrepancy:
have you opened the CVT?
Echo echo echo echoYes, what he said![]()
Yes, Like Hank and Toby sang, " A Little Less Talk and A Lot More Action "Echo echo echo echo
