2006 Burgman 400 - Silver - 8600 miles - and climbing !
Ok, so about 75% of the way back home on my return journey, around Amarillo, I noted that all of the sudden, my RPM's didn't drop at highway speeds like the Scoot had done consistently since about mid August when I installed the Dr Pulley 21g sliders & new OE Suzuki Belt + Malossi Yellow clutch spring.
Until that point in the trip, the RPMs were consistently around 6200 - 6400 for 74mph indicated.
Now, it's at 6800 rpm for 65 indicated, quite a downgrade.
When it first did this, it seemed to be stuck at this new higher rpm setting, then for about 20 miles, it re-functioned as before, with lowering RPMs - btw it almost feels like hitting the Overdrive button (WHEN working well).
Now, my conditions were totally demanding, IE I was battling headwinds, speeding Semi trucks, along with being fully loaded down, so I was probably pushing the edge of what this modest sized Scoot is capable of.
Probably she was operating at 98.5% of capacity.
Btw, other than the RPM's it runs at now, it all functions well, clutch action is smooth, no chattering.
So I was thinking / guessing what could have happened:
- Did I glaze my belt or burn the edges so now it rides lower in front pulley, from excess loads ?
- Did the Sliders wear the ramp edges to a sharp point, and now it restricts how far apart the front variator mech can spread ?
- Did something happen to the rear clutch, like the Malossi spring gave up ?
I'm not happy with it as it is.
This engine IS a high revving unit, so this doesn't preclude my using it, just makes more RPM's & slower cruise speed. And yes, MPG took a hit, it's now not at 65 mpg as the most of the trip was, but spot on 59-60 mpg, due ot the higher revs I'm sure.
My plan is to disasemble the CVT in search of the issue.
I'll have new Belt on hand, just in case, and I'll also obtain a new Suzuki factory CVT filter unit.
But hoping for insight on potential causes from you guys.
Many thanks ahead of time,
David
David
