I have a Break-Away throttle lock cruise control on my 2012 650. It is considerably cheaper then the electronic type. The Throttle lock device works very well on the Burgman. I think it is the best of the mechanical types. It is compact and well designed. One outstanding feature of this model is if you hit the brakes it instantly disconnects.Which cruise control works best on a 2013 Burgman? Is there an electronic unit or are they all friction?
Thanks Greg, PM me if you have any questions.I just ordered a Rostra Cruise Control for my 09 650. I'm going to use Redbeards excellent write up on his install and setup
http://burgmanusa.com/bkb/tiki-index.php?page=650+Rostra+Cruise+Control
Greg
Your profile says AN650K9, and if it really isn't an Executive I recommend getting the right-hand handlebar switch assembly from the Executive model, since the switch for screen height adjustment is perfect to use for the cruise control.I just ordered a Rostra Cruise Control for my 09 650. I'm going to use Redbeards excellent write up on his install and setup
Greg
The Rostra unit supports both normally open and normally closed contacts so you shouldn't need any relay.I'm discussing with myself how to do it, but the short version is that you need 2 relays, because the screen switch has "break" contacts, but you want "make" for the cruise control.
Oh! Oh! I see there is another person who will get spoiled! I love mine. It is the best money spent.I just ordered a Rostra Cruise Control for my 09 650. I'm going to use Redbeards excellent write up on his install and setup
Greg
