Hi Gang!
Last night, my 2007 Burgman 400 developed the weirdest electrical thing I can imagine.
1) The low beam doesn't come on at all when the switch is set to low.
2) Both lamps (Hi and Low) come on when the High beam switch is set to Hi. (Shows that the bulb isn't burned out.)
3) The front Turn signals flash OPPOSITE of what the turn signal switch is set to, but the back turn signals flash correctly! (I mean when you push the switch to the left to signal a left turn, the RIGHT front flasher flashes, but the left rear flasher flashes, and vice versa!)
This must be caused by some logic control box going crazy, right? All the bulbs are working, just at inappropriate times!!
Help!!
Thanks,
Bill
Help!!
Thanks,
Bill
