Again, a bit more thought in to how you check the coolant on the 400 (mine's a K9) would be appreciated. I like the idea that you can check it from the same area that you fill up with. However, the plastic that has the "gauge" on it makes it basically impossible to see if you're full, low or somewhere in the middle.
My suggestion, use a clearer plastic for the tank so you can easily see where the fluid sets on the marker between full and low.
