Bill,
The retarder braking that our Burgmans do is not entirely compression.
The transmission is sent into low ranges to force the engine into helping out.
As for the brake lights, I'm considering adding to the BurgyModule line with a "Retarder Braking" detection system that will light the stop lights for us.
A cheap method to do this would be to take advantage of the fact that our Burgmans have a switch that detects if the throttle is at idle.
A 1 second delay after idle detection, coupled to a brake light relay would give ample warning to cars behind.
A further variation of idle detection is being designed into the BurgModule line that will allow the rider to push a button so that the Burgman would not Retarder Brake at all and would just coast by moving the range motor into high gear until Speed pulses are at 9mph.
