1 - 8 of 8 Posts
I’m getting code C41 she started driving fine but started sputtering, then she would die in the middle of driving I have to turn her on again. But now she doesn’t power at all
c 41 is fuel pump/pressure first thing , have you done anything to it just before this started, even washing it? second, if you can hear,(i can't) when you first turn on the key, do you hear the fuel pump run?
I’m not sure where the fuel pump is located, and she was working just fine, where would I wash it?
just washing in general, like maybe water got in some electrical connector,, you should hear the pump, if no noise when key switched on, we will know where to start
lots of connectors, the pump is in the tank under the seat, the relay is up by the front forks
ok guys, I'm out, there is a power commander involved, and speedo inop, no noise from fuel pump priming, this is above my pay grade Seeth needs someone with more experience than me
Reactions: Uncle Fester
1 - 8 of 8 Posts
