I've got some noise coming from the clutch assembly of my wife's '09 400 with around 11k miles. It sounds to me like a dry bearing. The inner clutch cover bearing (17) was frozen on the shaft when I removed the inner clutch cover so, replacing that was a no-brainer. However, the noise only occurs until the clutch fully engages (or, with the engine off I turn the rear wheel), I have concluded it must be either needle bearing (1) or, bearing (3) on the diagram since, once the clutch fully engages, the drive shaft and clutch assembly become stationary relative to each other and neither bearing would be "rolling". I replaced the needle bearing and the other one felt well greased and seemed to roll smoothly by hand (without having removed it from the fixed driven plate). I put it all back together and still get the noise. I've also noted with the wheel off the ground it wants to turn at idle, further indicating a bearing is dragging. So finally, my questions. Does someone more experienced concur that bearing (3) has to be the culprit? Can it be removed without totally breaking down the clutch assembly (the manual only shows its removal as part of the clutch disassembly)? Finally, even though it is brand new, since I will have to pull the needle bearing (1) in the process, is there a likelihood that would damage it, so I should plan on replacing it again, as well?
[attachment=0:1ysgak7h]Clutch Assembly.JPG[/attachment:1ysgak7h]
