Just out of curiousity which way do you guys with 400's turn the dip stick to ck the oil. If you turn it with a flat side faceing up & down for example the oil will be higher on the bottom side than on the top side.
Or do you turn it with the flat turned sideways or left and right where it may show the same on both sides? :?:
