21 - 40 of 46 Posts
The best way, for me, is sitting on the floor, straddling the wheel, and working from both sides.
I use a stick gauge, reach in from one side and press down with the other hand; the same goes for filling ... I use the same type of chuck shown earlier, but without the clip. Very basic.
The hardest part is getting up off the floor. :)
I also have the tire pressures inconspicuously written on the trans cover and fork leg as a reminder.
I use bicycle tire inflator, a maxi one, with shorty valve stems
To check psi, use air pressure gauge with 45° head
Wrote recommended psi on all 3 scoots- all are different 🙂
1) Adjustable (!) Air Chuck:
This is another possibility, one that I forgot I had on my shelf:
the motion pro chucks and gauges have swivel heads and dont leak.....they make the process easy.. pricey yes but like carhartt work clothes buyem once...
2012 Burgman 400
Discussion Starter · #27 ·
Yes, those look nice, I'm going to try to get to the dealer some "cool" morning and challenge him to check the air and show him the text where I asked for 90degree valve stems and see what he says.
angled extenders are great for airing up and checking just remember to take them off , just remember to take them off when done and chuck them in the glove box so valve stems don't get leaky, ir in the 400's case, impact the bike
Reactions: BurgDanno
I have one, can't get in there, it would be good if it was a "reverse" 45...
Check out that Motion Pro gizmo I mentioned earlier. It can obtuse and acute angles.
2012 Burgman 400
Discussion Starter · #32 ·
So...I got this at Harbor Freight, solves my problem for now. Tires were a little over-inflated, but they were warm after a ride this morning. Think I'll order those nice angled stems, though for future use.
Wheel Tire Bicycle tire Crankset Automotive tire
These are what I think I will get, will they fit? Then I'll have them if I need them.
2 Black Ariete Bridgeport 90/83 degree 8.3mm angled valve stems Made in Italy | eBay
NO!!!
11.3mm not 8.3mm
Pick your color
What @Dave_J wrote.
And as I wrote in this post ...
Kurvey Girl is a very dumb name, but a very reputable on-line shop, one that I've ordered stuff from for at least a decade.
Here is that site's colorful valve stem assortment, similar to the product that you linked to:
And here's a colorful page from Sound Rider, another long-time outfit that I can personally vouch for:
And, last but certainly not least, here's Kurvey Girl's page on which you can see that Suzuki uses nothing but the more common 11.3mm rim-hole size:
2014 Burgman 400
Mine are probably the same Chinese quality :unsure:, 11.3 mm is the stem hole diameter in the wheel, I installed mine facing the right side easier to access on side stand, facing the rear left could interfere with CVT case ??
Tire Wheel Automotive tire Synthetic rubber Tread
21 - 40 of 46 Posts
