First large tire I have changed (in 58 years).
The front tire...
I made a home made bead breaker. Used 24 inch tire irons from HF. Wish I had a third one!
And a HF balancer.
The whole thing wasn't too bad. Ended up with some scratches on the rim. Despite using short, slitted lengths of 1/2 inch PVC pipe as rim protectors.
When I balanced it, I ended up with four 1/4 oz. weights, I put them between the spokes, instead of on the flat part of the rim. Seems to work OK. And the weights are centralized. Can't see any reason that wouldn't work.
Saved $$$$ and stayed away from a dealer. Give it a try if you are handy.
The front tire...
And a HF balancer.
